blu_fuz
New Member Classroom vulture
I have read through all old post of how to install the contour class1 hitch and havn't found anything for the actual install. I bought a SVT hitch used with no hardware or instructions and need to know bolt size and grade, if I have to drill some or all the holes, and any techniques for the install. I think I need 1/2" grade 5 bolts and some nuts & washers or possibly some "U" bolts....
It looks like only two of the 4 bolt holes are already in the underside of the car but there is no place to put a nut/bolt in the body for mounting......
If you have a copy of the directions or know anything, please help. Thanks - JOE
I found this link that seems to have pretty good info for general install: http://www.etrailer.com/faq_installtips.aspx
AND I found this PDF but my hitch doesn't have the bumper bolt locations, only 2 holes for each side of the frame (4 total): https://www.hitchsource.com/docs/cu/11113.pdf
AND found this PDF from hidden hitch that looks to be what I have: http://www.etrailer.com/instructions.aspx?pn=60979
