My friend, along with printing equipment that has so many belts and sprockets you cannot count them, I have high perf tuned, degreed cams (both single and twinned) on, and otherwise, worked on many different types of engine, both bike and car. Please don't discount what I say, at least I can think out to understanding how all the 'neutralling' of cams in the universe does nothing at all to change how the sprockets equal out themselves AUTOMATICALLY under a belt. If you will, having one cam or two (or three) should have no difference on how belt pulls them. If two cams must equal their sprockets under the belt teeth then explain the difference as to why only one (keyed no less) does not. What about engines with twin cams, belt drive and non-moveable sprockets?? And while you're at it, please explain why I do not need to loosen up the crank sprocket same as the cams so that crank can 'neutralize' under belt also. Tell me why the engine knows the difference. I've explained clearly why you do not need to, but you have not made a case for why I need to other than your saying so. Maybe you and others look at the engineers as gods, I do not. They are no smarter than anyone else, just more focused. This procedure is not nearly the only thing I have second guessed engineers on. and I have been pretty much right to my benefit on the other things too.
It's obvious that the belt wander/shredding quit because tension was changed incidentally while someone thought they were 'neutralling' cams.
The idea about the 700 inch motor was that motors are motors, they are all the same once you know how they work. Apparently you think they work differently. We never 'neutralled' that belt drive/sprockets either, even with .700" lift.
30 or 40 weight oils are not considered 'heavy'. While you're at it, please explain the logic train that proves the heavier oil breaks VCT. I'd be curious to hear it. Just talked to some NIASE mechs about it, they say what I did.
Gotten lucky a few times? I have pretty good luck with the race motors. None ever blew up unless I pretty much predicted they would. This zetec is a tinkertoy to me, I figured out the cam thing the first time I did one. Too bad somebody else still hasn't after many and now sells videos on how to do it.
As far as facts, produce some. I'll weight them and keep as worth something or discard as useless. So far though, all I hear is I'm right because I've done more than you, or, copy the manual, it can't be wrong. Those are not facts and my head feels fine.
I have gotten into it with Rockwell International press engineers also, I was right then too. They rewrote some press maintenance procedures based on one of those discussions.
Since the sprockets are pulled by a flexible belt, they actually are recentering themselves under the belt teeth with every revolution they turn while running. Belt gives and takes all along the way, making the variance worse. VCT action will change the tension. Makes all that talk about 'neutralling' cams silly since they rock around under the tooth in use.
Get more basic, when you loosen sprocket, you are simply moving the cam, it can be anywhere across 360 degrees. Has NO EFFECT WHATEVER on how the sprocket fits in the belt teeth. Read that AGAIN. If it did, custom cam timing as in degreed race cams would be impossible. As soon as cam was degreed to other than stock overlap the belt would shred, or so we are told...............
You are saying we cannot increase or decrease overlap for custom tuning. I should point out that 22 degrees of full VCT movement is more than the 1 mm. between the sprockets you talk about.
I remember going through some of this same stuff in mid '70s with Ford SOHC fours. All the mechanics said the engine was problematic and could not be rebuilt without all kinds of problems. All kinds of you can't do this or that. I never had a single problem, the motors lasted forever.
