I'm sure it's best to use the matching timing stuff, but the tensioners look almost the same. As said, they're slightly different but some people are using 3L tensioners on 2.5L's with no problems.
And as far as timing, all the manuals make it look too difficult when it's super simple. Just match the dots with the crank in the correct positions (I did my according to ford cd, tdc for front and 3 o clock after 2 rotations which I think was actually more like one rotation and then 3 o clock, depends on what you consider a rotation i guess). Match the dots like the manuals say to, turn the crank by hand a few times and if it's not impossible to turn then you should be fine. The manuals talk about timing marks lining up on the back of the cams but only my rear lined up, front never did, but it doesn't matter. It runs and runs good.
