TRicker
You running on stock tune still? The PCM can adjust for the 20% increase in displacement in open loop but I'd be very curious to see your A/F and such while in closed loop under wot.
yeah. stock tune. only things changed are the maf housing is now a 75mm pro flow and the MSD ignition (stock timing remains)
the wideband cuts out (bad connector on the guage itself) but when i get it to work it is good, but its idling a little lean. its still running rich at 12.5:1 but that's a safe range at WOT. we'll see how she dynos!
