GIT-R-DONE
are they interchangeable? i pulled out my old linkage and its a different style then the ones i pulled from the junkayrd. just wondering because i would like to finish swapping them before i put the motor back in.
There is no SVT specific linkage. It's just a difference in the years. What year did the parts come from?
...and they attach to the shifter correctly....
full cable set are interchangeable as a set. Just can't put new style ends onto old style cable.
It sounds like you pulled cables from a late-00 Contour. They use a different cable design. Late-99 to 02 Cougars also used these cables. The early style cables had replaceable ends that can be ordered from Ford seperately. The later cables were only sold as a set and typically it was the cable itself that broke requiring the set to be replaced all together.
A couple pictures from NECO:
Old style cables are on top
New cables on top in this picture
I would like to think that the newer cables are a better design.? Maybe that is why they redesigned them. I put in the new style cable in my car because of this, and the old cable ends are hard to find. The only issue with replacing with the new cable is that it is kind of pain to swap them, unless you have really tiny hands!
As of just a month ago, because the old style black cable ends are discontinued, I ended up buying a new set of cables (as documented in the MTX pops out of first gear post) and I was told that the cable ends for the new style cables were not replaceable because they do not show up as separate parts in the catalogue. I hope they are a better design and that they work better than what I am having taken off. The possibility of snapping one of these newer style cables gives me pause though. I wonder which one is the most likely to snap? That could inform one of some other problem with the shifting mechanism and or the MTX itself.I think they are. I don't see any other reason they decided to change them. Ford still carries the ends/collets to the earlier cables actually.
Karl
