I wish it had more low end, but I am guessing that because they used such a small supercharger (for packaging reasons), it doesn't move enough air at low rpms to produce "Mustang" like low end power. The other thing is the boost level, 9.5psi max on my boost gauge, lower now with the aftercooler (Buckshot) at some 7.5 to 8psi. Vortech most likely kept the boost under 10psi as not to blow up the Duratecs. :shocked: (or because of their computer chip tunes at the time).
Frankly, I would think that because there is a blow off/bypass valve in the set up, we could run smaller pullies (but not to overdrive the supercharger past its efficiency) to bring on the boost sooner and use a boost controller to limit the maximum boost to a safe level.
Even though I don't drive my SVT much, it's still fun to play with. Another thought. I could get an adjustable Turbosmart Bypass valve with built in adjustable boost level and try that. :laugh: The Vortech kits use the same basicBosch bypass valve as with VW 1.8T's.
