I decided to start a new thread to clear up the vacuum line issues I am having while installing the ST220 uim. Pics always make things much easier,
The largest port on the back of the UIM I am planning to use as the port for both valve covers if possible, this one
This one I will use for the brake booster vac line.
And use one of these for the vac line coming from the collage of smaller colored vac lines, and then plug the other as it has no use. Or would I be better off using each of these for the valve covers and then use the port on my intake tube for the smaller colored vac lines and plug the larger port on the rear of the manifold since it is being a PITA anyways?
And finally use this port for
This hose as it seems to have to go to the IAC which I learned the hard way.
