I still think everybody else is barking up the wrong tree thinking this is the result of an oiling problem.
Jaged,
Track down the noise. If it proves to be in the bottom end of the motor and not something like a failing hydraulic lash adjuster, compare the condition of your connecting rod bearings vs. the main bearings. If the main bearings look great but you have a spun connecting rod bearing, that is a very obvious indicator that the problem is with the connecting rods themselves. If it is an oiling problem, there will be significant damage to the main bearings (Note: nearly all the detailed reports I have seen on Duratec 2.5 and 3.0 spun connecting rod bearings found no damage to the mains). Continuing on, if the mains look great, get measurements done on the inner bore diameters of the remaining good connecting rods and compare the results to the manufacturer's specs. My guess is that one or more of the undamaged rods will be at the very top end of the spec or just outside of it. They will probably measure as having an oval distortion too.
If you find what I think you are going to find, upgraded connecting rods are the fix.
Terry was saying this years ago people. I still don't understand why everyone thinks it's an oiling issue, if it was ALL the lower end bearings would be toast.
