I am getting clutch slippage in 4th and 5th gear. What hapens is at low rpms in 4th and 5th I get rpm spikes after shifting. I let off the gas and it will go ok then. When I go through the gears at higher rpm's I am not getting any clutch slippage in the upper gears. Should I just replace the plate or any ideas on what is causing this?
