elraido
I kant speel
http://www.crutchfield.com/S-yGLHV2...spx?I=1085723CF&search=infinity+kappa+572.3cf
Ok, I thought I solved this but I guess I didn't. I have a set of the speakers linked above. One of them would cut in and out so I took things apart and found out that there was a bad solder in the board in the "box" part of the speaker. So I solder that back up....hook it back up...crank up the music and it works. But now that is only when it really wants to work....is when the music is cranked. Sounds great with it turned up....cuts out when I turn it down. Bad solder? Other connection? Headunit?
