J JDog New CEG'er Joined Jul 14, 2017 Messages 14 Location Depeyster Ny Aug 27, 2017 #1 Anyone know what the problem is when you shift into third gear and you get a slight grind going into gear but fine once in gear?
S speed_cat CEG'er Joined Jan 30, 2010 Messages 222 Location Reading PA Aug 27, 2017 #2 Your synchros in third gear are going bad
J JDog New CEG'er Joined Jul 14, 2017 Messages 14 Location Depeyster Ny Aug 28, 2017 #3 That's what I was thinking but hoping something easier could be solution. Thanks
S squeek Hard-core CEG'er Moderator Joined Feb 25, 2012 Messages 1,136 Location Blacksburg, VA Sep 1, 2017 #4 I had a slight grind in my third years ago. Gear oil drained and fresh in. Ran for about 400 miles or so then drained and changed the oil again and issue is gone. Maybe i was just lucky, or just some contaminants.
J JDog New CEG'er Joined Jul 14, 2017 Messages 14 Location Depeyster Ny Sep 1, 2017 #5 Well thats worth a try. Thanks
F FrancisPennysac Veteran CEG'er Joined Dec 13, 2014 Messages 502 Location PA Oct 5, 2017 #6 Does it only grind at high rev? or all the time..
J JDog New CEG'er Joined Jul 14, 2017 Messages 14 Location Depeyster Ny Oct 5, 2017 #7 It doesnt grind if rpms are real low...but driving speeds for 3rd gear it does a quick grind
L Lordred New CEG'er Joined Sep 23, 2017 Messages 29 Location California Oct 10, 2017 #8 Possibly syncro in 3rd is gone. Time to double clutch till you want to yank the trans.
B BrApple No Life But CEG Moderator Joined Dec 23, 2001 Messages 21,686 Location Gales Ferry, CT Oct 10, 2017 #9 BTW the MTX-75 does not use gear oil.
