side marker light how to
BrApple
No Life But CEG
Moderator
Gales Ferry, CT
does anyone have the sidemarker light how to fromt he main page? I found a digram of how to wire them up so that you get half bright with parking lights and full bright with turn signals. what it doesn't say is what diode to use and and want to see what the how-to said for resistors as the diagram I found said use 2 10 ohm/10w resistors in series
These are instructions for installing 1998 Audi A6 side markers. The reflectors are clear, thin, and rectangular with amber bulbs. I think they're also used on the newer A4s. You can get them from your local Audi/Volkswagen dealer. VW might have different part numbers, but they are the same components. The parts list is below:
P/N; description; unit price (list).
4B0-949-127; turn signal reflector; $7.50 ea.
161-949-111; bulb socket; $2.70 ea.
N-017-753-4; amber bulb; $1.90 ea.
[Picture 1]-------------------
You will need to modify the reflector. It comes with many flanges and a clip even. File them all off with a rasp or dremel tool. If you file it down enough, they will fit with no modification to the fender. Otherwise just enlarge the hole in the fender with a unibit or dremel and use touch-up paint to protect the exposed edges. Use 3M double-sided foam tape to mount the markers. The reflectors won't fit perfectly flush. I found that the 3M tape is just the right thickness to cover it up without protruding too much.
The side markers can be wired for single state operation (on with parking lights only or turn signals only) or two-way operation (full-bright with turn signals, half-bright with parking lamps). I did the latter, pictures are available under my profile. The schematic is available here (Thanks to John Miks for the help.):
[Picture 2]-------------------
Done this way, you'll also need two electrical components per side:
30-ohm, 20 watt resistor
3A rectifying diode
Radio Shack might have these parts; I found mine for under $10 total at an electronics surplus store. The resistors I bought were wire-wound and encased in sand. The diodes were rated up to 25V but anything above 15V should work fine. Depending on how you route the wire, a rubber grommet may be needed. Look around the hood hinge; you should see an approx. 1-inch hole there. From there you can route the wiring to the fender.
I used six splice connectors. Three per side, one for the parking lamp filament, one for the turn signal and one for ground. Remove the headlight assy (three screws) and you will see the wires that need to be tapped. Black is ground, the other two are orange.
With the schematic, it should be self-explanatory from here. A picture is worth a thousand words, heh. But just in case: I used a clothes hanger to run a 4-ft length (12V) and a 5-ft length (ground) to the fender hole through the hood hinge hole. I then soldered them to the copper spades of the side marker socket. I then ran the 12V lead to the components, soldered the connection and used heatshrink to cover up any exposed wire. From there, two 1-ft lengths were routed to the headlight assy and splice-locked to the parking lamp and turn signal leads. The 5-ft ground lead from the side marker was also splice to the assy ground. All lengths are approximate.
