SHOBros Stage 1 Cam Tester
hey now
hey now
ok they arent free u still have to pay for the testing tuning and send a set back as i was told through emails. but other then that u seem a good tester
ok i live in calexico near me is a dyno shop in san diego what i need to ask to the dyno guy????? and what else i need to do?? i am new abouth the dyno, i never made one
I have a couple potential potential testers right now, so I dont want to get too many poeple lined up right now. I can put you on the side as a back up if things dont go through.
We would prefer that you can tune the contour yourself, or the shop can to ge tthe most out of the cams. The cams will drop right in and you should see some gains but to get the most you need a proper tune.
If you were to do it you would need to dyno it before getting the cams. Then after you install the cams dyno it again with a tune. We want the dynos to show the gains of the cams.
I am going off of what I have understood. If some one cares to correct me thats fine. I have understood that secondary cams do not work well in oval port cams.
Damn and the quickest, fastest, best handling, best driven ( :p ) Duratec (NA) uses split port SVT cams on an Oval port 3L engine.
Guess my porting & air flow theory plus driving skills are superior then. ;)
