this is my compairison between the SE and SVT PCMs
My stock PCM was code LTZ3 and the SVT PCM was SFG0
both plots are adjusted by SAE and have a smoothing factor of 5
here is my dyno from last Spring Zing
SVT airbox with drop in K&N
optimized SVT tb
SVT UIM and LIM
Optimized y-pipe
SVT main car
SVT exhaust
151 hp/151 ft-lbs - all pulls done in 4th
now the only change made was the SVT PCm and the SVT 19# injectors
156 hp/148 lt-lbs - first run in fourth and the second two where in 3rd
now the biggest thing i noticed is that the A/F is better, not as good as it could be but better
also I lost alittle torque ....
next up for modifications are SVT cams and headers ... then finally a tune
any thoughts?
optimized SVT tb
SVT UIM and LIM
Optimized y-pipe
SVT main car
SVT exhaust
any thoughts?
