Rx Racing “Street Demon” Series 485HP Package questions
PurdySVT
Pontiac,MI
is this "kit" worth anything or is it just junk? just seems to cheep granted it looks like alot of tubing fabricating...... but for $400 I think I could justify paying an exhaust shop to fab some exhaust tubing or do it my self... I searched and didn't find anything on this kit so I though I would ask the experts.
[FONT=arial,verdana,helvetica,sans serif] Rx Racing “Street Demon” Series 485HP Package [/FONT]
[/FONT]
Brand new “Street Demon” Series turbo package for your vehicle. The most complete turbo package available for the price. This package has all new quality parts that are capable of producing well beyond 485 horsepower at 25+ PSI with supporting modifications and a built motor. This is the most complete package available compared to others at an affordable price. On a stock motor the kit will create give the motor a 50-100 horsepower gain on a low boost setting of 8 PSI. Also, the included electronic turbo timer provides a hassle-free operation of precisely calculating the cool down period to ensure a proper cool down for your turbocharged motor. Works with either automatic or manual gearboxes. This kit may allow you to keep your air conditioning and power steering for a great street setup.
[/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) Hybrid Turbo Charger: [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif].57 compressor wheel trim mapped for low and high boost setups[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Oil fitting gaskets & mounting studs included[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Capable of producing over 450 horsepower[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Wet float bearings & properly balanced[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]3" inlet diameter with a 2" outlet[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]50 A/R compressor housing[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif].63 A/R turbine housing[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]1/8 NPT oil inlet[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]T3/T4 hybrid[/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) Front Mount Intercooler: [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Large design cools down the turbocharged air efficiently [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Strong TIG welds will support high PSI levels [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Lightweight aluminum racing intercooler [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Extra thick core provides ample cooling [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] 2.5" cold outlet & 2.5" hot inlet [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Less then 2% pressure drop [/FONT]
[FONT=arial,verdana,helvetica,sans serif](1) Universal Intercooler Piping Kit: [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Lightweight yet strong aluminum piping [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] May necessitate light modification to fit [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] (16) stainless steel worm gear clamps [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] (2) 2.5” 90 degree silicone couplers [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] (6) 2.5” straight silicone couplers [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] (2) 90 degree 2.5” bends [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] (2) 60 degree 2.5” bends [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] (2) 45 degree 2.5” bends [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] (2) straight 2.5” pipes [/FONT]
[FONT=arial,verdana,helvetica,sans serif](1) Boost Controller: [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Can be setup to adjust boost PSI on the fly [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Can be adjusted for any PSI level desired [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Control your boost with a precise click [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Includes complete install kit [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Anodized aluminum finish [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] CNC machined design [/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) Slim Cooling Fan:[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Fan can be used to cool: A/C condenser, oil or transmission cooler, mounting on an intercooler to prevent heat soak, or cooling a a2w radiator [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Slim design provides excellent engine bay clearance [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Includes the mounting tabs for a easy zip tie install [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Reversible design can either pull or push air [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Versatility of a push/pull reversible fan [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Superior flow of a curved-blade design [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Creates additional aftermarket cooling [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] 1.25" thick outside perimeter [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] 2.50" thick inside perimeter [/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) Electronic Turbo Timer:[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Ensures a proper cool down for your turbocharged car every time [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Includes pigtail wiring and extra wiring for ease of installation [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Important to preventing premature turbo wear and failure [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Mounted inside the vehicle for on the fly adjustments [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Precisely calculates the cool down period for the motor [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Auto mode feature creates a hassle-free operation [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Increases turbocharger's operating lifespan [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Bright Easy to read LED Digital Display [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Failure to reduce the temperature of the turbo could result in "coking" of oil inside the turbo [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Coking is the baking of oil, turning it into a grimy substance [/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) 10 Meters Heat Wrap:[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Heat powers the turbochargers turbine inlet. Keep the heat inside the exhaust pipes [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Heat kills the turbochargers compressor inlet. Keep the heat out of the cold piping. [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Control additional engine bay heat and prevent overheating. [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Keep intercooled air cooled. [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Made of very high temp fiberglass. [/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) Stainless Downpipe:[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] 2.5" Inlet [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Waterjet cut 5 bolt flange. [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Mandrel bent stainless steel [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Beautiful TIG welds [/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) High Flow Intake Filter:[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Protect the turbo system from debris [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Instant HP adder [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Extreme high flow [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] 3" inlet perfectly matching the turbocharger inlet [/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) High Flow Breather Cap:[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Keeps crankcase ventilation clean for emissions [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Works in conjunction with the catch can to keep inside of turbo piping oil free [/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) Coolant Sensor Bung [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Monitor the water temperature via this sensor relocation [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Easy solution to run aftermarket coolant sensor [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Provides more precise readings then the stock location [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Features 2 installation clamps for an easy add on [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] 38mm ends fits most OEM coolant hoses [/FONT]
  • [FONT=arial,verdana,helvetica,sans serif] Strong Aluminum construction [/FONT]
[FONT=arial,verdana,helvetica,sans serif] (1) Non-divided T3 Flange[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Water jet cut for precision flow[/FONT]
  • [FONT=arial,verdana,helvetica,sans serif]Mild steel for easy welding to an adapter pipe or direct to stock manifold[/FONT]
You will not find an exhaust shop to fab you anything remotely close to what is needed to turbo your contour.
x10
But if you could do the fab work yourself :) then this kit wouldn't be that bad as a starter kit. Def gonna need a few more parts to make that intake kit work with the turbo.
x10
yeah I'm pretty confident I can do the tubing fab work and yeah I understand there is more I need
such as
injectors I have some 24lb but 42lb lightning would be better
a tune xcal2 or 3
a svt focus fuel pump
boost, oil pressure, fuel pressure and a wide band guages
oh a LSD and zetec final drive would be nice...
I do have an extra engine and trans to do the fab work off of....
and the clamps in the kit were listed as gear clamps so yeah junk....
I just worry that the turbo will break quickly...
You get what you pay for :(
You should do a remote setup Purdy :D
yeah that is what I figured but if it is a t3 t4 flange it seems like I might be able to upgrade turbos later
as for a remote setup what are you talking about beans? do you have a turbo?
By remote i mean rear mounted at the exhaust, and the cold side comes all the way back.
No i don't have a turbo, i have to finish my car sometime :crazy:
I thought that is what you meant and I'll have to pass on that I'm not interested in gutting my interior
mounting the turbo where the cat sits sounds more realistic but still a pain
yeah I have much work to do on my car too:nonono: damn contours :cry:
I'm just curious, have you ever seen a turbo kit installed on a tour in person?? Im not doubting your abilities but the fact that you are considering buying a $400 universal ebay kit isn't a good sign.
But anyway, give it a shot, take alot of pictures and keep us updated.
Someone with a 3L Se did one, you don't have to gut your interior.
Is this the same car that ran pvc piping?
Yes, i think it's really a cool idea for these cars considering the engine bay already is about as tight as it gets.
Just a little bit more engineering and a little less PVC i bet it could turn out really well.
That made me smile. :) And yes, Purdy has seen the engine bay of a Turbo SVT! He could do it, but I wouldn't start with a kit that has a turbo included for $400. You would be better off buying cheap universal pipe kits and buying a turbo/intercooler separate. I don't think I'd ever put a turbo on my car that cost under $400 alone. That thing probably has TONS of shaft play straight out of the box, and I'd also bet it'd blow oil pass the seals upon the first start up.
yes I have seen a few turbo cars engine bays namely Reebs and LivinSVT.
on Reebs I was lucky enough to see it apart so I got a good idea what the tubes look like so yeah I have an idea what I would be getting into.
yeah Jeff the only thing that saves the kit is the t-3/t-4 turbo flange as I should be able to upgrade the turbo when the cheep china crap blows up...
I did know the kit looked to good to be true and I have real misgiving about that but it is also along way from $2000-$3000 kit and there is so much more expense needed..... I just thought the kit was worth mentioning something interesting to talk about. granted I do believe the NPG kits have great value and are pretty cheep....
this is a daily driver and I don't like the idea of my turbo hanging down below the car...... maybe for a fair weather car that is never driven on a dirt road or in the rain....
You didn't catch my point Neal! It will blow out as soon as it sees any oil pressure... so the first time you start it! That turbo would blow oil past the seals from day one. I promise. :D
personal experience?
all this is hypothetical because at this point no turbo kit is cheep enough but interesting none the less...
As cheap as the kit is it can be very usefull. But if you get a t3/t4 kit for instance. Pick up a t3/t4 garret turbo the needs to be rebuilt, because the kit turbo will not last long. blaast performance uses a very simaler turbo setup. But if you pickup a cheap garret on ebay that needs to be rebuilt. use the garret turbo and you should be fine. Garret turbo around $50 on ebay rebuild kit around $70 on g-pop shop + kit = good turbo setup.
http://floridahondacrew.com/forced-induction/12745-beware-blaast-performance-turbo-rebuilding.html
I wouldn't buy that kit. Non-roll beaded piping, non-reinforced silicone, hose clamps not t-clamps, and a questionable turbo. Chinachargers are fine just buy one from a reputable company (cx racing or etd)...I built a remote kit the lowest point of the turbine is about an 1" below the bottom of the roll resisstor im gonna be reworking it a little bit later on just for the hell of it but it's only about 2 inches behind the center of the front wheels so the chances the chances of it actually hitting something are slim, obvioulsy a little careful driving is in call for but its not really the turbo you have to worry about they are fairly robust its the lines and fittings you really need to worry about. A scavendge pump is also needed for a remote setup it will cost you about 115 for a Shurflow.
*edit* ps that kit isnt even really a kit because the IC piping is cake the hard part is making the y pipe which it gives you nothing except the flange to do. Also you would want 2" hot side charge piping.
