svt_cougar
About a week ago i had my 99 svt taken in to have a new front drivers side wheel bearing installed. The next day i went to put new pads and rotors on. When I got finished I went to go in reverse out of the drive way and heard a metal on metal rubbing sound on the front drivers side where the wheel bearing was replaced, so I took it down the street and it was making the same noise still. So I got back into my drive way and took the wheel off and noticed that the inside of the rotor is rubbing against the caliper bracket. I can see the rubbing imprint on the bracket which is how I can tell what it's rubbing against, also the inside of the new rotors has been scratched on top of it from rubbing on the caliper bracket. So I put the old pads and rotors back on, and going in a straight line they don't grind, but when i turn sharply they will grind, specifically more when i turn sharply left.
Do you guys have any clue what could be causing the inside of the rotor to be rubbing against the caliper bracket like that? Everything was installed and tightened properly when I put the new pads and rotors on so that's not the case. Also, it seems like when I mount and tighten the lugs on the tire is when it starts making the grinding noise on the new pads and rotors.
Can I just grind off the part of the caliper bracket that is rubbing or can you pin point to me what is happening here, because I've installed plenty pads on rotors and this is the first time this occured. Thanks in advance.
I was reading up on this and it looks like a few people used a 1/8" washer to fix the problem. Would I have to use 2 washers where both caliper bracket bolts go? Also, I'm assuming the washer would go between the caliper bracket and the knuckle correct?
