You got it! That is exactly it.
For the three in the rear, you will need a long extension, and make sure you have a Spark plug removal socket (has a rubber ring inside that holds the spark plug in the socket so that it doesn't fall out and crack the porcelain, etc.)
I find the easiest way to get the socket/extension in the rear three banks is to place the extension/socket/plug in the bank on its own, then add the socket wrench after its in there. Be careful not to scratch or marr the walls while inserting the plugs as well (just go straight down...)
Make sure you GAP the plugs. "pre-gapped" on the spark plug box means NOTHING for this engine.'
