Monkay619
I realize that my post is kinda long, so this is what I am looking for/asking:
1)What does the bank 1 pre-cat look like (any suggestions on a relatively inexpensive place to get one?)
2)Since this is my DD, should I fix the problem (replace the pre-cat) or save $$$ and ignore/bypass it (fooling he CEL?)
This is what my problem is:
Got my car back from the mechanic (it is my DD), and my CEL is due to the Bank 1 pre-cat (apparently the one bounded by the firewall). And I need a new intake manifold gasket. All together I’m looking at $1200, of which $1000 is from the pre-cat ($641 parts and $3?? Labor)
Considering that that is a bit more than ¼ what I paid for the car :nononoand I have had it for just over 1000 miles) I wanted to explore my possibilities before I put more money into it (especially if this is a sign of what is to come, maybe not a good idea to put too much money in). BTW, is that normal for the pre-cat to go with just over 75k?
The way that I see it as of right now, I have 3 options (any ones that I missed?):
A)Replace the pre-cat and pray that never happens again.
B)Not do anything, keep the CEL (and the worse MPG right?).
C)Install an o2 Mil /simulator (MPG as B).
Now if money were not an issue (but I just got engaged:help, I would do “A” since it takes care of the problem and emissions (oh, if there is a pre-cat failure, what is it due to? Should I not be fixing that, thus fixing the problem, not just the symptoms?).
I could get away with “B” since I just got the car, and will not need it emission tested for another 2 years. The only “problem” I see with that is I would not know if more CELs would be coming on, since it would be on all the time.
If I were to go through with the “C” option, then I would get decreased MPG, no CEL and pass OBDII when emissions come around. From my preliminary research, they can be made for less that they sell for assembled for $40 (what doesn’t cost less to make) and are relatively simple to install (but I have not grasped that yet, where does it go? The wiring harness I’d assume, right by the O2 sensor?:shrug
Now I have been looking for replacement pre-cats, but have been finding it difficult to nail down what I need because of the diversity in nomenclature. I read here that everyone calls them “pre-cats” however online parts websites do not have that distinction, they seem to all be Catalytic converters. Moreover, they tend to call them “front” when it is by the radiator, and then they have “rear” and ones that are not specified…. So is the rear one the last one? Or the middle one (which I need right?) I think that they refer to it as rear in terms of the 2 pre-cats? All this would be less confusing if I knew with certainty what the part looks like…. Is this the sucker: http://www.discountconverter.com/direct_fit_catalytic_converters/direct_fit_detail.cfm?productID=172:shrug:
Let me also make sure, the pre-cats are the same for all Duratec (ie SVT and non SVT), as long as they are MTX?
Side note about MPG (you will have to follow my rambling a bit more on this one, and I promise it will make sense by the end): I have only had the car for maybe 3-4 tanks? So I do not yet have a solid grasp of my MPG, but I do know that my best was 24 MPG on a trip with mostly highway, and going easy on it (not spirited as I usually drive), which gave me just barely over 300 miles to the tank I think I get closer to 280 on a tank (which equates to 23.3MPG) from what I read on here, that is terrible, and most of you seem to be getting at least 350 miles. Average EPA estimated yearly mileage is what, 15k? I’m in college, so I’m not going to put on that many, maybe 10k? so over 2 years (because I will need emission testing then, and if I do not pass I will need to put replace the cats for real) 20’000 miles, if I get 23.3MPG that is 857 Gal, if I get 28.3 MPG (that is 340 miles per tank, taking 10 off the 350 to be “conservative”) then I would use 705 Gal. If I save those 152 Gal @ $3 I would be saving $456 (aka the cost of the Pre-cat, but not the labor). So my point is that it might be better to just replace pre-cat in the first place.
Any additional information/insight is much appreciated, I hope this was the "right" section to post in
Thanks in advance
~Mike
Thanks in advance
~Mike
