For Sale reinforced rear subframe.
svtfixer
Yonkers, NY
have a reinforced, sandblasted and painted rear subframe. it is currently not drilled for brackets yet but can be for either a stock bar or bat bar. ive done several in the past and its a must for the bigger bar. will come with the massive shackles and poly bushings for the appropriate diameter.
its 250 located in new york.
this is the album for the black one.
http://s912.photobucket.com/user/rfddrums/library/subframes/black subframe?sort=3&page=1
this is the album to my frame thats currently on my car.
http://s912.photobucket.com/user/rfddrums/library/green sub
it has the bar bar and shackles on it with poly everything. mine is drilled to take 3/4 nuts, custom tubular arms and the hubs are drilled and tapped to take the 3/4 bolts as well.
for now the black sub is reinforced for a bigger bar, and not drilled for anything else so it will bolt up and you can use everything else stock. this can be changed if desired.
CLASSIFIEDS RULES
Last Updated: 7/20/22
