rear sub question
None the less you are wrong. There is AC current flowing in automobile systems
I'm really not sure what it is I said you are so desperate to prove I was "wrong" about.
The issue was inducing noise - I guess the quote you're trying to call me out on was this:
If we had high current AC flowing through the pwr wire it would be a problem, and we'd have to treat it like the plague when it comes to placing signal wires. Thankfully, it's high current DC which makes it a non issue.
I did mention high current, I stand by my statements, and I've provided outside info to support what I've said. I believe I've made good points and my comprehension of the issues are dead on.
If you disagree, super. Say you disagree.
I'm still waiting for you to enlighten us with the source of these dreaded noise inducing AC currents you've mentioned. It would be good info to have - maybe we could avoid some possible noise issues, but all we're getting is, "You're wrong."
There is AC that runs threw a automotive electrical system. No matter how good the recifier is there is still a bit of a sine wave on top of the DC. That AC can and does induce noise into certian setups.
Hense alternator wine. Noise induced into audio system. Ever wonder why its not present when the car isn't running?
Its not that I don't know what i'm talking about here. I am a EMC Test Technician. Specializing in Radiated immunity and Raditated Emissions testing. In normal people terms how much RF it takes to make something fail and how much RF something gives off. Everything with a transistor unless its countermeasured gives off RF.
Ohh ya, also a MECP first class installer, with 2 degrees in Avionics and Electronics.
So when I say you're wrong. Hate to break it to you buddy but your wrong.
You don't need high current AC to indunce noise. I can induce noise into a car audio system with a single transistor. Since speakers play sine waves any induced noise into said wiring will be picked up amplified and played.
Also who cares about static magnetics, the AC current running down your powerwire for your amplifier can create a RF field. Which in turn can couple itself to any metal object and create a mild magnetic field. Enough to effect anything? Probably not
Again, there is AC flowing down your power wire. That ac can induce noise. What else would you like to know.
it's a valid theory - but I disagree that it is a noise source in a car. Those are a few hundredths to a few tenths of a volt ripples that are absorbed by the battery. It is, however, a great explanation from a stumped technician to an uneducated customer.
no, didn't care, never had much in the way of noise problems. The only thing I can think of was in my 79 datsun years ago. It was an issue with the original AM radio. Replacing it with a basic JVC eliminated the noise. In hindsight I would say it was a ground loop issue with the cheap stock radio, but I'm more than willing to admit I'm not sure.
Are you talking about radiated noise? All I can say about radiated noise is that the industry experts I have communicated with dismiss it as a non-issue in a car. I haven't studied it, I know nothing about it personally.
Great - everything I've learned about induced EMI on my own good time because I'm interested in electronics and science in general says otherwise. And I couldn't care less about your Marketing Electronics to dumb Consumers with deep Pockets certification.
(indunce -- :D -- that's funny)
Again - I have no idea how a transistor would effect noise, or why I'd want to know. I would expect, however, that if it were switching at a frequency in the audible bandwidth it could be a source of audible noise.
Also, I don't know how much current is needed, but I know it takes at least a volt of AC fluctuation. Any less is not enough for it to be AUDIBLE. Any more and you have a defective alternator.
Also who cares about static magnetics, the AC current running down your powerwire for your amplifier can create a RF field. Which in turn can couple itself to any metal object and create a mild magnetic field. Enough to effect anything? Probably not.
I don't care about static magnetics as it relates to this topic either, but I stated magnetic fields in general don't induce audible noise in adjacent wires. You said I was wrong. The speaker magnet reference was simply pointing out that a magnetic field -"in general"- which a speaker magnet clearly produces - would not be a noise source.
nothing. I'm sure some small "noise" component is there, and that AUDIBLE noise is not.
If you happen to have a powerful amp and some speakers laying around - try this -- connect a pwr and ground wire to the batt. Run them on the ground away from the car and hook up the amp. Run some signal wires from whatever's convenient, an mp3 player ought to work fine - connect the speakers and turn it up. Do whatever you want with the pwr/signal/speaker wires - twist them, braid them together, loop them however you like -- TRY to produce audible noise - you'll find that it can't be done.
I've said my peace. Hopefully you've said yours.
I don't think either of us has been particularly moved by the other's thoughts.
If we're lucky a few people got something out of the discussion. If not I guess we've both wasted our time.
1. it's a valid theory - but I disagree that it is a noise source in a car. ...It is, however, a great explanation from a stumped technician to an uneducated customer.
2. but I'm more than willing to admit I'm not sure.
3. I haven't studied it, I know nothing about it personally.
4. And I couldn't care less about your Marketing Electronics to dumb Consumers with deep Pockets certification.
5. Again - I have no idea how a transistor would effect noise, or why I'd want to know.
6. I don't care about static magnetics as it relates to this topic either.
This is what I got out of this:
1. You are condescending.
2. You are unsure.
3. You are not formally educated on the subject.
4. See number 1.
5. You admit your ignorance on the subject.
6. You don't care about key points.
Quite frankly, all these indicate that you are not an expert and that you like to fight. We're not lucky and you have wasted my time.
1. I condescend as I am condescended toward.
2. I'm willing to admit that I'm not the all knowing authority on the matter
3. Formal education and practical application do not go hand in hand
4. see number 1
5. about some things, sure.
6. And Steeda doesn't care about mine.
I like to "discuss" - as this is a "discussion forum".
Not an expert, but have spent a lot of time reading and learning from those who ARE experts (engineers) in the field of CAR AUDIO, have studied all types of equipment in all types of cars and know exactly what does and does not cause noise in a car.
Again very interesting, as the stuff you said doesn't cuase noise, indeed can. For the reasons I have already explained.
This a discussion forum, but when you are stating your opinion and not facts it is no longer that. Don't like it? Don't know what to tell ya.
man, ya'all should get out more.
there's more to this debate than the great Steeda's preachings.
I'm not even debating the principles of what CAN cause noise - but electrical noise does not necessarily equate to audible noise.
I do get out.... I do installs almost every day.... So I get to see this kinda of stuff and problems on a daily basis.... plus being certified and being able to apply it to my job come in handy.... Cause if you understand something and why it happens you can better explain it to a customer and they will feel more comfortable with your work because they can see you know your :censored::censored::censored::censored:... just my $.02
