Where did you get your roll restrictor inserts at? I cannot find them anywhwere.
Jim
....But once you get it out and are ready to put a new one in, I have a suggestion for a part to add to the rear roll restrictor before reassembly... I am not sure if the mount is exactly the same for 95-00s, but if it is then you can use this:
http://www.ultrarev.com/product.php?productid=41317
This is a Front MTX roll restrictor Polyurethane insert... HOWEVER, it WILL fit into the ATX Rear Roll Restrictor!! It is a little tighter fit, but it will help prevent the inner rubber insert from ripping apart from the tranny flexing back towards the subframe when shifting... for the $15.00 its worth it IMO...
Good Luck!![]()
