Lexxer
I just recently clear coated my IMRC cover, and I noticed the belt under the cover probably needs replaced. Does anyone know what this belt is called? Thanks in advance.
Up to you I guess....chances are it's already been replaced.
I'm at 156k miles I'm on my third pump.
I'm at 157k and still with original Ford pump.
No issues but I do carry a new metal impellar pump, gasket and belt in my trunk at all times. Murphy's law says it won't go out if I carry the spare.
You're cruising for it. You should change it before it breaks because the last thing you want is an overheated engine (when it breaks) and you do not notice the temperature going to red.I'm at 157k and still with original Ford pump.
