I have the 2 Volume Service Manual set.
I read and re-read it a few times. I think I got it now though.
But when it says install the cam caps loosely, does that mean set them in their positions but not tapping or pushing the dowels completely into the heads? Cause later in the steps it then says to tighten the cap caps in multiple passes, I assume this is what pulls the cam caps completely down? Is the camshafts supposed to be loose so I can move it to install the roller followers?
Also, order in which to install the cam caps. It says to not install the thrust caps before installing the cam caps. I take this as...
1-put camshaft into the head
2-loosely put the cam caps in with bolts
3-install timing chains, guides, tensioners, etc.
4-install roller followers
5-align camshaft by installing thrust caps
6-torque cam caps down in several passes
7-after cam caps are completely torqued down then proceed to torque down the thrust caps in several passes
Correct?
I got the assembly lube and I am ready to start putting things together.
Correct?
