turbojimbo
do i use the 2.5 pulse wheel or the 3L pulse wheel. do i put the pulse wheel on the 3L the same way it came off the 2.5, or spin it to the other key way, 05 sable with 3L cams and timing chain with 2.5 timing cover.
Yeah, keyway should be OPPOSITE of the missing tooth when using the 2.5L timing cover. Doesn't matter what pulse wheel you use, it just needs to be on correctly.
My '95 pulse wheel looks a little different, but you get the idea. Keyway on the crank shaft is through the pulse wheel. Notice the missing tooth around the outer edge.
It only has one notch to have the pulse setting for a 2.5L timing cover only. Nicer? I gues so, but what does it matter? It's not going to fail no matter if you have the stamped steel one or if you have a '95 one like mine..... :shrug:
Just install it like mine, who needs 35 teeth anyways :laugh:
