ButtonPuncher
To do this mod, you need...
A small pipe cutter (available in the plumbing section of your local hardware store)
22mm or 7/8" crowsfoot wrench
A K&N 62-1340 filter. (Or any other that will fit a 5/8" O.D. pipe.)
I purchased mine from Summit...
http://www.summitracing.com/parts/KNN-62-1340/
First, unscrew the EGR pipe from your catalytic converter. It highly suggest soaking the fitting that screws into your cat with Liquid Wrench (or any other penetrating lubricant) and waiting 30 minutes or so. Unscrew with the crowsfoot wrench.
My pipe cutter was an Imperial TC1050 from Ace Hardware. It was the most compact one that I could find.
Take your small pipe cutter and clamp it on about 1" or so from the bracket that bolts to the underside of the coil bracket.
Rotate the cutter forward and back. Tighten the cutter a little each time you make a forward/back motion. It takes a while but you will eventually start to see a cut forming. If you keep rotating the cutter in one direction, it may corkscrew down the pipe instead of cutting it. Back and forth is the way to go.
Once it makes it through, you will have a nice clean cut. Be careful because the inside edge will be sharp. (Don't stick your finger in there. LOL!)
The filter has a nice thick lip where the hose clamp goes on.
Push the filter onto the pipe a good 3/4" and tighten down the clamp.
There still a bit of clearance between the filter and the AC line.
K&N logo...
I haven't had a chance to do long term testing on this mod but it should work just fine.
BP
K&N logo...
BP
