greasemonkey1489
The code means that the Cat efficiency is low, so that means that the preset value for the downstream O2 is out of the range that the ECU has programmed, thus a fault. Possible reasons for the cat efficiency being low would be a rich-running engine, or just rich exhaust.
One big problem with these cars (v6 Duratec) is the EGR passages clogging in the intake manifold right behind where the throttle body mounts. Also the failure of the EGR valve itself due to carbon and a poor design. The EGR valve is vacuum operated so the EGR solenoid may not be able to tell that the valve is not completely opening.
Back to the EGR passages.. if the passages are clogged, then the engine cannot cycle exhaust gases back through the engine to "dilute" the fuel/air charge causing a slightly "rich" condition. EGR systems are to reduce emissions and increase fuel economy, especially at cruising speeds (>45mph). SO, if the fumes are too rich, the downstream o2's sample the fumes and the voltage reading indicates a "low efficiency" after the catalyst, you get a lovely, orange CEL.
So, pull of those throttle bodies, test the EGR valves, scrape out that carbon and let's see what happens...!
I have had the 420 code cleared 3 times and it has been back after both downstream o2's were replaced.. Cleaining my intake stuff this weekend and I will clear codes and update.
