Popping when making a right turn! HELP!
qbcsvt
Up North New Jersey
Hey Guys, I am still working on my suspension due to low funds..... Man longest suspension swap in years Im guessing LOL!!!
Regardless, When I make a right turn either slight or hard I get a Popping when accelerating. I can drive fairly regular when going straight or making a left turn without any hastle(I dont drive the car only move for street cleaning). It seems as if the Popping is coming from the Drivers side.
I am thinking I may have messed up the CV Joints when installing my suspension and this may be the cause and the whole AXLE (half shaft/cv joints) is causing the problem. I just would like for somebody to confirm or give me a better sense/explanation. Also if you can included a linked or quick how-to on how to replace the piece(im lost on the axle/scared to deal with anything being taken out/inserted into the tranny.
Currently changed is:
Struts/Coilovers
Inner and Outer tie rods
Will be changed: LCA's, HUB/Bearing/Knuckle Kit(both sides)
Thanks in advance
I need to get my car up and running I havent driven it in like FOREVER!!!!
- amyn
Sounds like textbook bad CV joint. I'm headed off to bed as I'm falling asleep otherwise I'd respond more fully but since you asked for confirmation I thought I'd throw that out there. :cool:
I was thinking the same, Should I end Up replacing axles or just the drivers side(as the popping seems to be coming from the drivers side)??? Also if that I couldnt find a how-to that specifies what parts are needed. Like any o rings, clips, special tools.
I was thinking, Remove caliper, Disconnect LCA, Remove Hub, and then....
Do I just pull out the axle, is something holding it in? Do I have to remove the boots?
- amyn
I was thinking of using a Slide Hammer and putting it on the rear CV Joint closer to the tranny.
I believe there is some type of lock ring in there and I dont want to damage anything and get stuck or messed up. Also when re-installing does the axle pop right in or does it need some force for that???
- amyn
