Hello guys, i recently did a scan on my 99 Contour SE V6 and below are the codes i got.
I need your advice/assistance to know where to start handling the issues from.
Diagnosis by OBDScope.
www.obdscope.com
Date: 01.07.2014 15:16.
Vehicle id: N/A
MIL: On.
Inspection status: Failed. MIL is on.
Fuel system status: Closed loop, using oxygen sensor feedback to determine fuel mix.
Secondary air status: N/A.
OBD Port Voltage: 14.70V
OBD tests: 4/8 completed:
Misfire: OK
Fuel system: OK
Components: OK
Catalyst: Incomplete
Evaporative system: Incomplete
Oxygen sensor: Incomplete
Oxygen sensor heater: Incomplete
EGR system: OK
Lambda Tests:
Short Term Fuel Trim B1: Varies between 2.3436% - 9.3744%
O2 Sensor B1S1: Varies between 0.1150V - 0.8000V
O2 Sensor B1S2: No variation, 1.2750V
O2 Sensor B2S1: Varies between 0.0900V - 0.8400V
O2 Sensor B2S2: Varies between 0.5450V - 0.7650V
DTCs:
P0743(current): Torque Converter Clutch Circuit Electrical
P0500(current): Vehicle Speed Sensor Malfunction
P0401(current): Exhaust Gas Recirculation Flow Insufficient Detected
P1131(current): (No description)
P1151(current): (No description)
P0174(current): System too Lean (Bank 2)
P0136(pending): O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P1132(pending): (No description).
Freeze Frame:
DTC: P0174
Calculated Load: 39%
Engine Coolant Temperature: 69?C
Short Term Fuel Trim B1: -3%
Long Term Fuel Trim B1: 7%
Short Term Fuel Trim B2: 29%
Long Term Fuel Trim B2: 25%
Engine RPM: 7431/min
Vehicle Speed: 0km/h
Also, my radiator dires up very quickly and i fill it up everyday.
The mechanics around me are not very competent and they only do things on trial and error.
Your response/advice/recommendations would be highly appreciated.
Thanks in anticipation.
www.obdscope.com
Vehicle id: N/A
MIL: On.
Misfire: OK
Fuel system: OK
Components: OK
EGR system: OK
Lambda Tests:
DTCs:
Freeze Frame:
DTC: P0174
