using a funnel w/ a 12" flex tube that had a plastic cylinder if you will at the end to keep it firm. the plastic piece was on the inside of the flex tube and is about 1 -1.5 inch long with about 3/4 inch opening straight thru. using to pour in fuel injection cleaner. somehow the plastic insert came out and went down the tank.
how bad is it and what to do?
