why was there 11 quarts? for some reason it isn't adding up for me. I can only fit about 4 1/2 in mine.
do you have a zetec or a duratec?
zetec is suppose to take 4.5 quarts of oil .... but I put 5 in mine just fine ...
I fill mine to 6 quarts and it leaked twice :blackeye:
It just happened again. 3rd time now, but I was at work this time. Left the office, started it up, ran for about 1 minute and I hear the "gurgling" again :nonono: I called the oil place again and they said they are too busy to leave the shop and they probably can't do it tomorrow either. I am going to pick up a motorcraft filter or something tonight. I am ready to![]()
Could I possibly have 3 bad filters in a row?
or your oil pump bypass valve is stuck closed.
I will only use the Motorcraft filters on my svt. When my brother and I built his tour motor he bought the WIX filter, which I him told not to, but he doesnt listen, and that was the result. All of the oil all over the floor. So I had a extra Motorcraft filter that we put on and it was perfect.
hey wait......
get a real big allen wrench and make sure your oil cooler isn't loose. if your filter was overtightened, it could have backed out a bit when they took off the filter. highly unlikely, but if you keep having the same problem.....
Ohhh snap, i never even thought about that.This is my only hunch right now. I think the media blasting material that I use for blasting parts for powder coating is ending up in the oil pump. "Black 98 svt" has had the same situation happen to him and seems to be right after he also installed his freshly powder coated valve covers.
I should have cleaned my valve cover insides after blasting WAY better (like toothbrush and magnify glass cleaning). I think the brown hue that was on the underside of the valve cover from the media was the oil pumps ultimate demise.... pole120 and I are pushing to get the motor pulled and install a new oil pump before SZ. It will be tight, but I will do whatever I can.....
SO EVERYONE WHO GETS PARTS POWDER COATED, CLEAN THEM! IT IS NOT MY JOB TO CLEAN YOUR ENTIRE PART. I ONLY BLAST, CLEAN, AND POWDER COAT WHAT I NEED TO.
I am being punished for my own carelessness![]()
Non SVT...no oil cooler....
