Desiato
I don't think your guitar strings will hold if your hood came loose. I'd use something much thicker.
Whatever the hell thats supposed to mean. The reason I am pointing this out is because I dont run hoodpins, and would like some extra insurance as well.
^^^ those were what i wanted goonz, but i couldnt find them when i wanted to order. i got hoodpins from hoodpins.com (not sure if they are made anymore) but they are all the security you will need. sorry about the bad pic:
thats not a bad way to keep your CF hood secured in, good thinking!
I dont understand why you have a CF sheet replacing the Ford logo oval, just take the whole thing out :shrug:
Or get in touch with Parkedcar and get one of his over lays with SVT in it, rather then just a carbon oval. :idea:
Which is what the new rigged up device is hooked to, so in the end, it's still as compromise-able as before, yes?
I had the CF hood as long as you did or maybe a bit less, I never had a problem with it nor at high speeds (16hr drive to SZ06 and back) did anything go wrong with. With that said you dont have to buy hood pins necessarily, what I was planning on doing was to get the sleek Aerocatch pins. I believe Rick (Buckshot) had them on his, they looked awesome
The weak point is on the hood itself so.....if the hood latch breaks or tears u will keep that on your car. But BYE BYE CF HOOD. :shrug: I like pins but i also like the clean look of the CF. so im not even sure what im gonna do when i end up gettin CF.
- Amyn
