JesusFreak
You may not have to replace everything on this list, but it will cover everything I can think of.
from the top down:
EGR gasket
UIM/LIM gasket
Valve cover gasket to include the ring gaskets for the spark plug holes. Fel-pro sells it as a complete set.
Crankshaft bolt (Torque-to-yield)
Crank case gasket
Crank gasket
Head bolts (Also TTY)
Head gasket
Oil change
oil filter
new coolant
It will get expensive and will be difficult to do in the car but possible. The cams will have to come out to get to the head bolts. This will require you to be extremely meticulous on what goes where and everything must be kept in order. The bolts for the cams may be TTY as well, not sure.
You'll need a torque wrench, pulley puller, paper towels, degreaser (I swear by Simple Green. $9 from Home Depot for a gallon of concentrate.), beer, patience and more beer. Ok, beer isn't neccessary but helps dull the pain.
EDIT: If the car didn't overheat, chances are that the head may be ok. However, if it was a head gasket and in my car, I'd still have a machine shop look at it. They will be able to tell you if it needs to be decked or not.
I have a feeling car is going to sit if its not a fuel problem until I can afford to put it into a shop! Takings cams out and all that stuff, well, I jsut dont think I'm going to really trust the car any if I try and do it! I'll always be wondering, what did I mess up, or what did i miss!
