P0301... help!
Lt_hailBob
Charlottesville
I was driving down the road tonight going about 55mph and there was a pop combined with a flash from under the dash.(the console is currently removed) The car suddenly got REALLY loud. I checked under the hood and discovered one of the plugs was completely blown out. It was flopping under the hood with the spark plug still attached. It threw P0301.... cylinder 1 misfire.
My question is: Is the engine shot?.. if not (though unlikely), what could it be?
It is a 98 Ford Contour SVT with 137,xxx miles. I saw no fluids on the ground when I stopped.
try doing a heli-coil on the cylinder that blew the plug and see what happens sometimes spark plugs just pop out like that on engines....
The heli-coil will work as threads in the hole, several have done the same. check the site. I have no experience with this sorry.
I would start with replacing the plug and startn'er up.
I would start it up but it makes a horrific clunking sound. I'm pretty sure it's a spun rod bearing. I think It'll be heading to DanG's garage.
Don't start it until you put a helicoil in. This will allow you to reinstall the spark plug, which will take care of the loud noises you hear.
