SVT3391
Today is the first time I drove the car out for work after the MSDS headers were done. I also got a pair of MILs from Naulitus. I got the P0156 code on my way back. The weather was great with no humidity.
I searched. From Tony's post:
Before the header/MIL installation, I had P0420 sometimes but not very often. Does this P0156 means my Bank 2, sensor 2 is broken? Or just a bad connection? Again, there is no rain, water puddle or anything like that today.
To expound on what Ray posted and to answer your question a little more in depth, if the lower O2 sensor(s) goes bad, you get [FONT=arial,verdana,helvetica,sans-serif]P0156 [/FONT][FONT=arial,verdana,helvetica,sans-serif]Downstream Heated Oxygen Sensor circuit fault - Bank No. 2. or [/FONT][FONT=arial,verdana,helvetica,sans-serif]P0161 [/FONT](no signal sensor code). I got both these codes. The mileliminators are only there to eliminate the P0420 and P0430 codes for the lower O2 sensors.
Correct. I just used some last week for my battery positive cable. If I decide to redo the mileliminators again, I will use the Liquid Electrical Tape (aka liquid rubber) for the connections. Right now, whenever I drive in the pouring rain for 4 or 5 hours, I get the P0136. However, I just erase the code and it doesn't come back until the next 4-5 hour drive in the pouring rain again.![]()
