Decide what kind of driving you want to do, then determine if you'd like to lower your car a bunch, or only slightly.
From the suspension FAQ:
What springs are available for Contiques?
Both sport springs and coil overs are available.
Brand /Model /Drop Front/Drop Rear/ Spring Type(Prog/Linear)
B.A.T./ Sport/ 1in/ 1in/ Progressive
B&G/ / / /
Eibach/ Pro-kit/ 1.25in/ 1.25in/ Progressive
Ford/ ST24/ OEM/ OEM /Progressive
H&R/ Sport/ 1.5in/ 1.5in/
Intrax/ / / /
Rousch - No longer available from retailers!
Coil Overs:
Ground Control /Coil Over / ADJ./ ADJ./Linear
What struts are available?
Brand/ Model/ Adjustable?/ Lowering Advised?
Koni/ Yellow/ Yes/ Yes
Bilstein/ Sprintline/ No/ yes
B.A.T/ Euro / No/ With BAT or similar springs
Ford/ ST200/ No/ Spring perch is 1" lower, not necessary
KYB/ GR2/ No/ No
Sachs/ Super Gas/ No/ No
Spax/ Sport/ No/ No
I've got the BAT kit & I'm lovin' it. No scraped bodywork or exhaust pipes, firm, confident handling, slightly lowered - only about an inch or so, still a great ride for long trips. If you have bad roads where you are, you might consider your stock springs or SVT springs and a set of struts with a lifetime warranty.
