shavedsvt
the coil pack that your plug wires connect to. once that is removed you can feel that box. remove the cover. the sides of it are clips push in and pull off. once that is done take off the two nuts. they are 13mm take the cables off and take fuse off. inspect the fuse. i always replace fuses that arent seethrough just for good measure. put the two cables on their respective posts after the new fuse is put in place. then reinstall everything
