Are you building for turbocharged or otherwise boosted operation? Do these engines have oil squirters in the con rods? (I've never checked.) If they do, and you add additional squirters, you'll want to block the con rod squirters, or get different rods.
Generally, piston oil squirters are only used when an engine is going to see high levels of boost for long periods, road racing or land speed racing on moderate to high levels of boost, and diesels pretty much always have squirters.
That said, there are some good threads about oil squirters on TurboFord.net. Some of this bunch, of which I'm a fanatic participant, run oil squirters on high boost small displacement 4-cylinders. There are some good links to pictures in the threads.
http://www.turboford.net/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=050239
http://www.turboford.net/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=045535
Oil squirters do add to the crankcase oil vapor and crank windage load, so that's something to consider, and if not properly sized, can eat up a lot of the oil pump capacity, which might not be a good thing.
Squirters from the Ford Zetec 4-cylinder. These have a built-in pressure valve that closes at low oil pressure so they don't rob the engine of oiling during low load. The valve opens at high oil pressure (assuming high load...) to cool the piston.
Honda oil squirters are also a favorite.
Some also like the BMW oil squirters, tho I can't locate a picture at the moment.
Hope this helps.
Gary M.
