aguywithansvt
hi, i have a 98 svt with a 99 duratec swapped in and it has been having a problem leaking oil around the fill cap and other spots i have put in valve covers gaskets. it seems to be running to high of an oil pressure so i installed a gauge when warming up it sits just above 75-100psi and warmed up its at most 50psi. it also leaks the worst when coming to an idle and idling on the front of the engine. so if anyone has any ideas on why i'm running high psi when warming up and where its leaking from
