1999contour
Wow, just wen to the ford dealership to order the shift tower bolts, collets, and maybe clutch kit.
Bolt = 6.08
Collets = 25$
clutch kit (Disc, PP, tob, slave cylinder) = 450$
Needless to say i did not order the clutch kit. Can order a spec for that price. Any ideas on whats best for close to stock?
Now for the questions:
My friend used to have an se with v6 5spd and it would engage when the clutch was about 2 inches off the floor board, while my SVT is almost all the way out before it engages. Is this just an adjustment issue or clutch going? I have never had it slip or anything, and there is only 80K on it. Should i bother replacing the whole works right away?
My shift tower bolt is the reason for the work, and is stuck in 1st gear. A guy that i know has a shop and does all his work for 25$ an hour and works pretty efficiently (swapped a motor in my grand am in 4 hours so 100$.) anywho he said he would pull the tranny out for me but would not open it up. Once he has it out it seems like the bell housing has to come off and then just get it into neutral and pull the tower out of the top of the tranny replace the bolt and find the old one. This sounds too simple to me, or is it really not that hard once the tranny is out?
Any advice is greatly appreciated.
Sorry i guess this sould be moved to the mtx75 section... please move if you feel the need.
Bolt = 6.08
Collets = 25$
