NothernMystique
I know there is a similar thread for this below, however I want to ensure my terminology is correct.
When driving my car when at a low RPM (2000-3000) and a press on the gass the car lacks power/bogs out, and makes a deep exhaust sound, it actually sounds like the exhaust is plugged. If accellerate less aggresively, when I am over 3000 RPM and I floor it, the car takes off with great acceleration. It is only in the LOW RPM range that the car hessitates. It really seems like the car is cut off from fuel supply until I get to higher RPM's when she takes off.
I replaced the plugs and wires (stock wires, stock plugs) a few months ago and the car was running great. I had a similar problem about a 3 years ago, the car got so bad that if I pressed on the gas the car would bog down and eventually die. I had the fuel pump replaced back then and everything worked fine.
I recently replaced the fuel filter, with no positive effect.
I have ordered the FOcus pump from Bill Jenkins (YA Billy!) and will complete the install.
I think you guys may suggest I check the plug gaps, Could the length of the wires to the plugs make a difference? If I screwed up the lengths and (distributor to plugs are correct) had longer wires where the shorter wires should go- can that mess up the performance.
Help Help Help!
Peter
Help Help Help!
Peter
