s.rich06
NGK makes the TR5 plugs that i should run.
			they run different heat ranges. the number code on teh plug is the heat range.
example
NGK's part number for a copper core plug (standard plug) is TR6 (contour stocker)
the 3L is recommended to run a TR55
in my car i believe i ran TR5 plugs (would be 1 step colder than a stock 2.5L)
Correction:
TR5 is the standard heat range for the Contour. TR6 is 1 step colder.
Isnt the TR55 1 step and the TR6 is 2 steps?
Either way, run TR6's
ima do some experimenting
I will slowly but surely and record my results
Yea not yet. But only time will time huh
you mean only time will tell...
