hourang
I tried to adjust them by doing the reverse trick... I will look at them again. I know the adjusters get rusty and stiff after a while.
Thanks guys, you rock!
you should replace the adjusters if their bad.
Are the adjusters supposed to have a spring on them?
Also, when I go to step on the brake, it shimmies pretty good until I get slowed down quit abit.
I have looked and I only see stuff about the 'spring' on the front calipers needing to be on properly. This is ok on mine. Any other ideas?
Thanks.
