The Rest of the story - finis
OK so you all helped me and here are the results.....
Yesterday I started the installation of the harness I made up from the dash components to the trunk. At first I was optimistic about getting to Connector #246 (an in line behind the dash by the glove box), but after removing the pocket below the radio, the radio, the glove box and the glove box top cover I came to realize there is no way to reach it. this is where the blue/red wire is missing from the connector. Ok new plan..... hook up the other wires while you figure out the new plan....
Removed the panel below the steering column disconnected the battery, then after waiting 10 min or so, removed all the connectors from the fuse box, removed the fuse box, then removed the fuse box bracket. On top of this bracket are several other connectors I needed access to the blue one C-289 mostly as I had to add three pins to each side (M & F) first thing I find is that even though the pins look similar the ones from the 98 and the 95 I have are different so I can't just insert them. New Plan #2 take pins from spare wires I have, splice them on to the wires, and insert them. OK that works.. I have to connect the blue / white wire from that C-246 I can't get to, to C-289 pin #5, which I just inserted. Can't get to the splice which is in a raceway behind the dash so I find the blue wire (C-285 fuse panel) that provides power to it and solder a splice in to it where it is convenient to get to.
Purple / blue pin #4 goes to purple / yellow (C-283 fuse panel) I replace this wire in the connector with a section that had the splice I needed in it and solder splice it into the place where I cut it out.
Pin #6 that darn blue / red from that connector I can't get to,.... insert the pin and I'll get to the other end later.
Connector #298 into fuse panel bottom, find the orange / blue pin #5 and remove it insert new pin with 2 wires in it and solder splice it where I cut it.
Put all that mess back together only the loose end of the blue / red wire to deal with. I route it over to the hole for the radio making sure it isn't getting pinched or in a place it can get cut ahhhh got it. What the heck I crimp it to the wire in the radio harness marked Power Antenna (blue).
Now I hook up the power, connect the radio and check for proper operation before running the wires the rest of the way to the trunk. Turn on the key the antenna goes up and motor keeps running. I turn the key off, antenna goes down. Check power at the connector. power is everywhere it should be when it should be, but at that darn blue / red wire. Check continuity and it is good from the radio plug to the other end the antenna module connector #413. Plug in the radio and nothing coming from it. Put it all back together glad I didn't remove the other antenna yet, go have an adult beverage go to bed..... I'll try the amp power lead maybe this Alpine CDA7838 doesn't control a power antenna. I did find out this is a 1999 model head unit, and if it doesn't have power out at the amp lead I'm getting rid of it......
Such a deal........ what the heck an interesting adventure and preportory for the up coming fog light adventure......
