knapp302
Hi,
I just got finished installing a new clutch kit in my 98 SVT. I have everything back together and can't seem to get the clutch to disengage from the motor. I have tried a number of different ways to bleed the clutch master and throw out bearing with no luck. I'm sure the master cylinder drained out during the time the motor/transmission was out.
Is there a procedure that has worked for anyone I could try? Am I overlooking something?
Open to suggestions....I have a vacuum pump bleeder at my disposal.
Thanks in advance.
FYI, I basically replaced the clutch since I decided to remove the engine to replace the seized alternator......love that design! To be fair, I had a front manifold exhaust leak to fix too...
Thanks in advance.
