Need front rotor piston rings/boots
SvelteSVT
I have been searching for the proper size brake caliper repair kit for over a month to no avail. Does anyone have a part number for stock front brake caliper pistons for a 99 CSVT? I have tried:
O'Reilly (piston o-rings too large)
AutoZone (piston o-rings too large)
Chapman Ford Dealer in AZ (Can't locate the correct size)
Wow. I had no idea! I checked the size of the rotors and they are 278mm and I always thought it would have the larger caliper as well. I just ordered the non-SVT caliper repair kit. Thanks BRApple!
yes, SVTs have the 278 mm rotor. Only the 98 E0 SVT had larger calipers. Not sure how different the caliper really is, but it used larger front brake pads. All others the front and rear brakes are the same, except the rotors.
Part stores never have the correct information on front brakes for the SVT.
