Special thanks up to this point to the following:
BrApple - various great information
svttour - overall great advice
Livinsvt - transmission build info
Pudmunkie - transmission advice
ContourSVT99 - clutch advice
My first paycheck this year I started saving to build up my 98 CSVT.
So I guess I'll share my plans here where people are interested. Feel free to make suggestions, just keep in mind I'm saving for these parts and buying them individually and installing them as they get to my door. Also, I'll include the reasons why I'm installing them in this order.
*I am keeping the 2.5L in this build. I will replace it later with a 3.0 (or when/if it blows up).
#1 -Transmission Rebuild ~$1600 (Livinsvt)
I chose this first because without a solid transmission, I won't be going anywhere. I don't want a differential detonation on the track.
#1.5 - Spec Clutch Stage 3+ ~$550
This will be second, but will be installed at the same time as the HMS transmission in anticipation of the turbo kit. Keeping the stock flywheel because from what I've heard (and I'm most likely wrong) the fidanza flywheel won't make that much of a difference to justify the extra $300. *Also, Terry recommended that I use the OEM slave and not the one that comes with this clutch, so I'll take that off the order (-$59).
#2 - B&M Short Shifter ~$200
To shorten shift throws, of course. Also, I'm sick of punching my $300 CD deck.
#3 - Trubendz 3'' Cat-back Exhaust ~$600
To avoid bottlenecking once the turbo kit is installed. Oh, and the sound.
#4 - Battery Relocation ~$100
- X-CAL 2 ~$280
- NPG Turbo Kit Stage 2 w/ Turbonetics upgrade ~$3600
Battery relocation to open up room for the turbo kit, X-CAL 2 for tune and finally the turbo kit for the power I need.
#5 - BAT Euro Handling Kit ~$650
What good is all that power if it handles like a truck? Changed my selection of suspension based on price. Was interested in the Koni Adjustables but that's more novelty and I can't justify paying extra $ for a feature I will not use.
After reading up on all of the sub-forums, this is what I came up with as to what mods I want on my car to get the most performance for my money.
I read in http://www.contour.org/ceg-vb/showthread.php?t=30212 that DSS Axles and the flywheel isn't needed, so if I get them, it'll be later on.
I will be doing all of the installs myself or with someone willing to help me in my girlfriend's dad's shop in Perry, FL or the smaller stuff in my garage in Ocala.
To come after-
Paint Touch Up
New Headlights
New Window Seals
Tint Windows
Rear Sway Bar
Front Strut Brace
Tell me what you guys think.
EDIT #1 Clutch changed to Stage 3+
EDIT #2 Changed suspension choice based on price vs. performance.
EDIT #3 Switched HMS transmission build to Livinsvt. Price is better.
DO NOT HIJACK MY THREAD PLXTHX. PM ANYTHING YOU DON'T THINK QUITE FITS IN THIS THREAD.
- X-CAL 2 ~$280
To come after-
Paint Touch Up
New Headlights
New Window Seals
Tint Windows
Rear Sway Bar
Front Strut Brace
