jolly8286
as far as the MAF cleaning goes, I've used the CRC MAF cleaner and it works really well. But If i am correct, you're not supposed to use intake cleaner on a maf. I may be wrong. just my .02
			First, regarding career mechanics not wanting to give you some help, no one is going to tell you much without doing some diagnostics first. Did they offer to do that or did you just want the information for free? There are any number of things that can cause poor gas mileage and you might get the same number of answers (guesses) from the pros, just like you are here, without doing the diagnostics. If you asked at a Ford dealer, you might have cut down the list to the more logical things that could be the problem but they’d still rather run a diagnostic to be sure. I still think you should run a compression test first to make sure you have a sound platform to start with and low compression isn’t going to show up on the diagnostic scanner. Neither will a gummed up intake manifold which would be my second suspect if I were going to guess. :blackeye:
Karl
Yes, there's nothing wrong with free info but put yourself in the mechanic's shoes and decide how much time you'd want to spend doling it out when you could be spending that time on a paying ticket. That's all I'm saying. Go ahead and clean the intake and you can run the compression check at the same time. Post the compression numbers and then we can go on from there.There's nothing wrong with free info. If the compression was low what could I do? i will be cleaning the intake. Ill be starting the work tommorow. Thanks
I live on long island New York (suffolk county).
Today I replaced the ect sensor, cleaned the throttle body, cleaned the pcv filter, cleaned the idle air control, replaced the air filter, Cleaned the MAF sensor, regapped the plugs they were gapped .045 but the haynes manual said.050 so thats what i set them too, raised rear wheels to check for dragging brakes but they werent. I was going tochange the intake air sensor, and the temp sender but the guy gave me the parts fo a 98 by mistake. I disconnected the battery to "reset" the computer, and put a large bottle of Techron and filled her up Regular $3.69 gal.
Ill have a better idea if any of this made a difference in my mpg's once i run thorough a tank full
