aircougar
I Cleaned out my basement of all parts that I dont need anymore. I have been holding on to this stuff for too long, and it needs to go!
Parts are listed as INCLUDING SHIPPING (to lower 48 States)... If you are local, we can work out a price without shipping.
Also, if you want more than one part or a bulk amount of parts, I can adjust price for shipping, but depends on what the parts are... I will do what I can, but honestly these prices are pretty low in the first place. Please keep in mind that I work for USPS, and I intend to ship using this service... please do me a favor and dont ask for UPS or fedex unless there is a unusual circumstance that would require another service. thanks
this is a huge list and plenty of pictures... this parts are sold AS-IS, please ask questions if you are unsure of something... there are Contour and Cougar parts here, but most things will work for both vehicles, however there are a few things for zetec in here.
I will sell the entire lot of parts, plus a rear BC2 bumper, and whatever is left in my shed for $900.00, if anyone is interested in stock-piling parts (local pick-up only of course )
Here is the list:
Inline thermostat Controller for a temp gauge (good for ATX or oil coolers, screws directly into cooler)... $10
Dash cluster Bulbs (bag full of them)... $8
Cougar 3rd Brake Light Assembly w/ custom black vinyl cut-out
(a little scratched)... $15
Wiper Arm Bolt Covers 3 are Cougar, 1 is contour.... $5 each
Mega Fuse.... $3 each
MTX Shifter Reverse Lockout: Plastic stock... $5
Driver's Door window switches Pair (orange & blue ones)... $10
Driver's Floor mat hold-down clip... $4
Driver's Outside Door window Trim END PLUG... $8
IAT Sensor... $5
Clutch & Brake pedal Rubber pads... $8
Cougar Rear Bumper Light Housings (pair)... $8
SVT Fog Light Brackets... $5 each (2 left)
Vertical Door Hinge Struts 850lb rating (pair, will come with 2 Joints, but they dont screw into struts, will need a transition piece if used).. $20
Gauge Cluster Needles... $5
Coolant Resevoir Cap (top painted translucent red)... $4
Cougar Taillight Harnesses (pair)... $15
IMRC Plastic Guides for front valve cover... $3 each
Coolant Hose Clip... $3
Fuse Box Covers (99 and earlier models)... $8 each
IACV + valve cover Breather Hoses... $3 each
New Fuse Box Relay... $5
Contour Mirror glass w/ backing plate... $8
Cougar Hood hinges... $10
Coil Pack... $15
Contour Fuel Doors: T-red assm $8, Black door $5, Black assm $8
Cougar fuel Door laser red... $8
PULSE Wheel & 1 SVT timing Chain (NEW)... $12
Clean A/C Heat shield (over y-pipe)... $8
T-Red FORD Touch-up paint for chips... $6
DPFE off of a 18k mileage 04 3L... $15
Cougar Driver's side MIRROR CAP... $15
REAR Coil Spring Helpers for sagging springs... $7
Stock 2.5L Spark Plug Wires (came off my Cougar 3 years ago, were still good)... $15
Engine Covers ( 2.5L or 3L, have 2 - 2.5L ones and 4 - 3L ones)... $7 each
Cougar Mirror Glass (can fit either side of car, just the replacement glass)... $10
Midnight Blue Contour Head Rest... $20
2 Pairs of TWEETERS and one pair of inline Crossovers... $20
DEEZA inner Tie Rod... $15
Contour Early 98 and Late 98 Taillights (pairs)... $25 a pair
Optilux Fog/driving lights kit by HELLA (model 2020), paid $70, still new in Box... $45
9006 & 9005 used pairs of Headlight bulbs (still good filaments)... $10 for the set
"S S" CHEVY Emblems... from late 60's, early 70's.. one pair.. $15
Early Style Coolant Resevoir... $15
Cougar 99-00 Air BAG Set... $60
MTX Used axle... Driver's side axle... $25
99-00 Cougar REAR Spring seats (needed for 01-02 Cougs installing drop springs) $35
Contour 2 piece Hood cowl... $30
Passenger Side Fender Well Splash Guards... $15 each
SVT Gauge Clusters (for parts, Coolant gauges may or may not work?)...$20 each or $30 for BOTH
Contour Dash Bezel w/ vents (no broken tabs or mounts)... $30 (sold one, just acquired another one! still for sale...)
Power Steering Cooler... $15
CLEAR ACRYLIC Curtain Rods for ANGEL EYE project... $7 for both
Cougar Hood-to-cowl molding... $15
Hood Squirter Hoses: single line w/ t and elbow $8; Double line w/ t and elbow $10
Hood Squirters ( 2 pairs available )... $8 each pair
16 Cougar HEADLIGHT clips (holds 2 halves of light assembly together)15 in pic... $8
Polished COUGAR Center caps for 16" wheels... $6 each or all 4 for $20
CARBON FIBER "look" license plate frame.... $8
KKM "style" AIr Filter w/ MAF Adapter, gasket, bolts... $25
C-WEST Hyper Voltage Stabilizer... (used, havent tried it) $10
Clocksprings (have 3 of them)... $15 each
REAR VIEW Mirrors (2), one has a mounting tab for windshield... $10 each
KONI plastic Adjustment Knob... $6
Box Style REAR Control ARMs (pair)... $50
ZETEC K&N Air Filter for stock air box (used)... $25
COUGAR Stock AIR BOX (no MAF or filter), one missing clip... $15
Cougar Windshield Fluid Resevoir... $15
ATX Shifter Handle (wires were cut for O/D button)... $10
COUGAR HVAC and Light Switch BEZELs (painted silver frost, could use repaint)... $30
CONTOUR REAR Reflector Panel (was painted, good for project, includes FORD emblem)... $40
Stripped Contour Grill OVAL... $15
SVT Oval Grill ( one bottom tab is broken on side, one top tab is broken, but included with grill)... $30
ALUMINUM Contour Gauge Cluster Bezel (fits models withOUT Tachs) NEW... $35
PICTURES IN NEXT Post...
Here is the list:
IAT Sensor... $5
Coil Pack... $15
