In order to install mine I have to wait till the 65mm TB is ready. It needs both throttle stops to be fabricated. My tuner won't touch it unless he can adjust it.
LOL thanks,
I want to run it on my car first just to make sure that there aren't any problems with them. I also want to make a heat shield for the air cleaner, much like a K&N kit out of aluminum. If I feel realy ambitious, I'll make a complete cold air kit. I will let everyone know.
Well, I hate the way the throttle stops look. I was looking at both throttle bodies, I might be able to make the 65mm work with out any issues and look totally stock. Humm, a 65mm cold air kit...a complete bolt on with out any modifications. I'll keep you posted.
You'd be correct, I already did a nice port job on my UIM, no I need to port the metal SVT gasket or make a spacer.
That is to be determined.
Not sure on the HP gain, I'm going big now to match for a serious 3L later.
-J
