light in headlight switch
hgitter
My headlight switch does not light when the headlights are turned on. It has the white spot for a light, but it doesn't feel the same as the switches on the HVAC. Was the light taken out of the headlight switch or could my bulb be out?
It's a '99 SE
Nope, you should be able to replace it with a #194 bulb assuming the twist-in socket is still there. If it isn't, I suggest going to a junk yard and grabbing one as I'm not sure ones you find online will fit perfectly.
ok -- many thanks -- it seemed strange that all the other interior lights worked except for that one.
can you just pull the switch off to get at the socket or do you need to go behind the panel?
